Hi,
Im a lil confused as to what exactly should be put in the formmail.pl script...any help greatly appreciated.
# $mailprog defines the location of your sendmail program on your unix #
# system. The flags -i and -t should be passed to sendmail in order to #
# have it ignore single dots on a line and to read message for recipients #
$mailprog = '/usr/lib/sendmail -i -t';
# @referers allows forms to be located only on servers which are defined #
# in this field. This is a security fix to prevent others from using your #
# FormMail script on their web site. #
@referers = ('my-domain.com','65.65.665.665');
# @recipients defines the e-mail addresses or domain names that e-mail can #
# be sent to. This must be filled in correctly to prevent SPAM and allow #
# valid addresses to receive e-mail. Read the documentation to find out how #
# this variable works!!! It is EXTREMELY IMPORTANT. #
@recipients = &fill_recipients(tony@my-domain\.com');
i think the 1st 2 sections are correct (hopefully)...but im unsure as to how to send the results of the form to say [email protected]
Thanks in advance
Thanks in advance
